Quelqu'un connaît-il un procédé permettant assez facilement de réaliser une compression des fichiers vidéos en HD x.264 (720p et 1080p) pour faire tenir un film sur un seul voir deux DVD-R ?
Merci de votre aide et bonne année !
Procédé d'encodage en HD x.264 !
Pour passer du TS 1080i au x.264 720p tu as cette méthode :
System Requirements
a Intel Pentium 4 @ 3.0ghz or higher (DualCore Recommended)
a AMD Athlon 64 @ 3000+ or higher (DualCore Recommended)
1GB RAM or more
20GB+ in space
Good Time
a Movie with aspect ratio 16:9 with NO black bars only at the botton
Tools:
AviSynth > http://www.avisynth.org/
MeGUI: http://www.x264.nl/
DGIndex & dgdecode.dll > http://neuron2.net/dgmpgdec/dgmpgdec.html
TIVTC > http://bengal.missouri.edu/~kes25c/TIVTCv1RC2.zip
Step One: (DGindex)
1. Open .ts in DGindex
2. Set the right PIDs to Video and Audio
3. Change iDCT to IEEE-1180
4. Press the [F4] button
Step Two: (AviSynth)
1. make a .avs file with notepad
2. put this in it and change path\to & file.d2v
# PLUGINS
#LoadPlugin("C:\path\to\FDecimate.dll")
#LoadPlugin("D:\Download\degrainmedian08\degrainmedian.dll")
# SOURCE
MPEG2Source("file.d2v")
# IVTC TIVTC
tfm().tdecimate()
#Use Fdecimate when source is 720P
#FDecimate()
# CROPPING & RESIZING
# Note: if the source is 1280x1088 use the secound but if it isnt use the first one
Lanczos4Resize(1280,720,0,0,1920,1080)
#Lanczos4Resize(1280,720,0,0,1280,1080)
# DENOISING: (if you got noise)
ask in forum, etc for help, denosing can realy degrade the details
Step Tree: (MeGUI)
1. Load the .avs file into MeGUI
1.1. You shuld get a preview right after loading
2. Download the Nwgat HighProfiles ( Nwgat.HighProfile.rar )
3. UnRAR them into ( C:\Program Files\x264\profiles\video )
3.1. There are two profiles but the most common to use is Nwgat.HighProfile.8RF and its the fastest
4. Select a profile
5. Tools > BitRate Calulator > DVD-5(4GB) for a movie that is 1 hour & 40min or DVD-9 (8GB) for a movie that is 2 hours and 20min then apply
6. Change Filetype to mkv & Enqueue
Step Four: (MKVToolnix)
1. Drag both the .mkv file & the .ac3 file into input files in mkvmerge GUI
2. Click on the ac3 file & Make default track, Language (English), Trackname (Dolby Digital 5.1)
3. Fill in the DELAY that it says in the ac3 file like DELAY -***ms add then it on Delay (in ms): to -***
4. Start Muxing
5. Play it
