Comme le disait la niouse HDnumérique, Le lecteur HD-DVD HD-EP30 dézoné par AVforums:
Source:
http://www.avforums.com/forums/hd-dvd-p ... mware.html
Thanks to Viking61
Voilà la procédure du dézonnage "sale":
1. Insert the CD with firmware called EP30-dirty1
2. Answer Yes to update
3. The display will show VER UP for awhile, then count until STEP 2/4 before it stops with 10004050 showing on the display. The TV will still show “Updating. Do not turn off.”
4. Let it stay like that for 10 minutes
5. Unplug the power cord, wait 10 seconds and plug it in again
6. Turn the player on with the remote
7. There will not be anything shown on the TV
8. It will show WELCOME in the display for awhile, then it will show VER UP
9. Press Right Arrow (the button to the right of OK) once
10. Press OK once
11. The disc will eject
12. Insert the CD with firmware called EP30-dirty2
13. After awhile it will show VER UP in the display, then you press OK once
14. It will still show VER UP in the display for awhile, then it will count from STEP 1/4 until STEP 4/4
15. STEP 4/4 will take 15 - 20 minutes. Just wait and let it run it's course.
16. The disc will eject and the player will turn itself off
17. Remove the disc and turn the player on with the remote
18. It will show WELCOME for awhile and then a small update will run, only STEP 1/1 and the player will turn itself off again.
19. Turn the player on with the remote and you have a regionfree EP30
You can now update to version 4.0 and still keep the regionfree setting.
Les liens EP30-dirty 1 et 2 (merci à l'uploadeur):
http://rapidshare.com/files/164448855/EP30-dirty1.rar
http://rapidshare.com/files/164454428/EP30-dirty2.rar
Test sur mon EP30 OK.
Re: Le lecteur HD-DVD HD-EP30 dézoné par AVforums
Après avoir fait la modif tu es passé en 4.0 où tu l'étais peut être déjà ?
Merci pour ta réponse
Apparemment quelqu'un reporte un brick après avoir updaté en 4.0 après le dézonnage.
After bricking my Ep30 three days ago, I resisted the temptation to even unwrap my brand new boxed spare Ep30.
Had to succumb today, and immediately had to try the region free again.
I followed the instructions as before, deliberately and nervously used the exact same cd's as the last day, and this time it worked flawlessly.
So I guess it's just "one of these things" .
So hopefully will get my swapped out player back next week too.
J'ai rien dis
J'ai rien dis
